Author Topic: Help Identify a PCB socket  (Read 843 times)
Offline abqaTopic starter
« on: March 18, 2019, 11:11:51 am »
Hi Guys
I need help identifying a 5pin socket on a PCB in a heatpump so I can find a matching connector for it. It looks to have a pitch of 2mm
I suspect it is a molex or similar but can't find any that look the same.
I had some 5pin JST PH connectors laying around which are the right length but too wide to fit in.
I was wonderign if someone recognises this connected (See attached image)
Offline RES
Re: Help Identify a PCB socket
« Reply #1 on: March 18, 2019, 12:47:05 pm »
Looks like a PAP-05V / PAP-05V-S 2mm pitch 5 PIN PA JST connector.
« Reply #2 on: March 18, 2019, 08:51:57 pm »
Thanks that looks like it could be correct! I thought I had checked all the JST connectors
I will order some and check
