I acquired this a few years ago at a hamfest (see photos). It was built by Scientific Measurement Systems. I was told by the seller it was used to let a mainframe operator know which tape should be loaded on which drive. Anyone know what it actually is and how to interface it? The two connectors on the back are electrically linked - presumably to allow the displays to be chained. Of the six pins, two are ground and one is power. It seems to be OK with 12V. The connectors on the top seem like they'd be for lamps. They might be data inputs but it seems unlikely.
There's no CPU present on the cards. It appears to be all discrete logic doing whatever it does to the input and for multiplexing the display. I'm guessing the input must be something like synchronous serial due to the small number of pins. The rotary switches suggest it has a way of decoding its address.
