Author Topic: Making alarmclocks great again  (Read 3158 times)
Offline SuperchargedTopic starter
« on: March 17, 2018, 09:48:44 pm »
Im currently working on a Nixie clock, creative i know  :horse:, and i dont want to just use a booring buzzer for the alarm function.
But i also want it to be reasonably simple, i thought about using a 8-Bit sound chip, but they are not too easy to find.
My current Plan is to use a "DFPlayer" Mp3 module, which seems easy to implement into the design, but seems overkill.
Does anyon have a better idea what to use?
Science is about what is, engeneering is about what can be.
-Neil Armstrong
Online NiHaoMike
    • Facebook Page
Re: Making alarmclocks great again
« Reply #1 on: March 18, 2018, 02:17:53 am »
Encode the audio to a bitstream, save it into a SPI Flash chip, then use a microcontroller to clock out the audio. Note that the microcontroller doesn't need to do anything with the SPI data - just bit banging a read whole chip command followed by continuing to clock it would be enough.
Online Ian.M
« Reply #2 on: March 18, 2018, 06:35:28 am »
You can still get cassette recorders new, so get a cheap one, gut it for the mechanism and build a tape loop player.   Splice a short piece of clear leader into the loop and use a photosensor to trigger stopping it in the right place.
Online BrianHG
« Reply #3 on: March 18, 2018, 07:55:45 am »
Since you are going Nixie, I would say go for a few mechanical bells, at a different pitch each with their own single shot solenoid, & program a chime.  Like a 2 chime door bell.  In fact, go to a hardware store and just buy and old fashioned multi-chime door bell.
Or, if you must wake someone up, buy a fire alarm bell.  >:D
« Reply #4 on: March 18, 2018, 08:05:39 am »
I had considered that as well, but i thought it might annoy the neighbours
edit: I like the idea of a solenoid chime though.
« Last Edit: March 18, 2018, 08:47:24 am by Supercharged »
-Neil Armstrong
« Reply #5 on: March 18, 2018, 08:09:31 am »
Interesting idea, i have to look into that.
-Neil Armstrong
« Reply #6 on: March 18, 2018, 08:20:42 am »
Nice idea, but it'll probably take up too much space for what i'm doing
-Neil Armstrong
Offline Zero999
  • 0999
« Reply #7 on: March 18, 2018, 10:47:12 am »
Perhaps a miniature gramophone? Those were popular for voice effects in toys, before ROM became large and cheap enough.
Offline Twoflower
« Reply #8 on: March 18, 2018, 10:50:30 am »
If you use a espressif ESP32 you might have enough CPU power to fire up a I2S interface. Even the small predecessor had some capability to do so (it has a dedicated I2S interface). So you actually could run 16 Bit not just 8 Bit sounds with reasonable power consumption with normal audio DACs. The Wireless capability also allows automatic setting of the time.
How about mounting bass shakers beneath your bed. I had another idea, but you mentioned neighbours. So a train horn is out as well ;-)
Offline frozenfrogz
  • Having fun with Arduino and Raspberry Pi
« Reply #9 on: March 18, 2018, 10:56:05 am »
Maybe you can go all-tube for the signal generation? http://www.tubebooks.org/Books/vto.pdf
He’s like a trained ape. Without the training.
Online Ian.M
« Reply #10 on: March 18, 2018, 11:05:02 am »
However you then have the problem of constructing a recording lathe to cut a disk with the desired sound clip, and it will wear out pretty quickly.
Another option would be to use a mechanical music box mechanism.  They are compact and cheap, but unless you get the sort that plays from a paper tape, you are pretty much stuck with what's on the supplied cylinder(s).   You'll also need a really quiet gearmotor to drive it.
« Reply #11 on: March 18, 2018, 02:57:32 pm »
Interesting idea, but my powersupply doesn't have the power to drive the cathode heater for the tubes
-Neil Armstrong
« Reply #12 on: March 18, 2018, 02:59:38 pm »
I have already selected a MCU, and that module seems not to be the thing i was looking for.
-Neil Armstrong
Offline Gyro
« Reply #13 on: March 18, 2018, 05:24:31 pm »
What about a small low power mobile phone vibrator motor. Attach it to a flexible upright bracket supporting a bell or gong. A loose center hole in the bell would provide the 'clapper' action. Damp it to taste.
Best Regards, Chris
Offline frozenfrogz
« Reply #14 on: March 18, 2018, 05:25:10 pm »
Another option would be the re-enactment of the Sputnik beep via discrete parts :)
Fran has made a video about that and also provides corrected schematics. Looks pretty neat too!
« Reply #15 on: March 18, 2018, 07:11:26 pm »
Might take a look at it, at least it'll be a interesting video
-Neil Armstrong
Offline frozenfrogz
« Reply #16 on: March 18, 2018, 07:25:44 pm »
Here is a screenshot from another of her videos on the sputnik beeper model circuit.
There might be an actual schematic file floating around the web, but this should also just do fine.
The following users thanked this post: Supercharged
Offline NivagSwerdna
« Reply #17 on: March 18, 2018, 07:42:10 pm »
That's not true.  eBay auction: #181787542441
« Reply #18 on: March 18, 2018, 08:35:18 pm »
lets just say, i didn't know what to search for
-Neil Armstrong
Online ebastler
« Reply #19 on: March 18, 2018, 09:35:49 pm »
Another vote for a mechanical bell. One tone or two pitches, and not a jarring "rrrring!", but a nice, discrete "ping, ping, ping". (Or "ping, pong, ping, pong..." if you have two different pitches...)  :)
The two-tone bells from an old phone should work nicely, and sound much more civilized than they did in the phone if you discretely "ping" them.
« Reply #20 on: March 18, 2018, 10:39:58 pm »
Fair enough.
I'm playing with old arcade PCBs at the moment and they have an abundance of AY-3-8910 for a circa 1980 sound.
also... you can search YM2149F
Rather than sound... it could make you a cup of tea/coffee....? https://en.wikipedia.org/wiki/Teasmade
« Last Edit: March 18, 2018, 10:59:31 pm by NivagSwerdna »
Offline Cyberdragon
« Reply #21 on: March 18, 2018, 11:14:52 pm »
How much power do you have? Directly heated battery radio tubes don't take that much power.
*BZZZZZZAAAAAP*
Voltamort strikes again!
