Author Topic: Help identifying component?  (Read 553 times)
Offline St3venAUTopic starter
« on: September 16, 2019, 03:02:22 pm »
Hi, I'm wondering if anybody can help identify this component? It came from a 12v-240v inverter and was across the 240vac output. It failed short circuit (component tester show it as a 0.03ohm resistor). I'm guessing from the 103k that it's a 10nF cap, but I was unable to determine what the 26 above that indicated. Any advice on a replacement component? Thanks.
Edit: After digging a bit, I realised that the marking must be 2G (not 26 as I had read it as first) which indicates 400VDC. This surprises me since it's across the 240VAC output of the inverter, so I would have expected an AC rated cap. Does anyone know if it would be wise to replace it with a different cap, perhaps a 2T (250VAC) rated cap?
« Last Edit: September 16, 2019, 03:54:04 pm by St3venAU »
Offline amyk
Re: Help identifying component?
« Reply #1 on: September 17, 2019, 12:09:42 am »
240VAC is ~340V peak, so 400V would be ideal.
Offline SiliconWizard
« Reply #2 on: September 17, 2019, 12:20:57 am »
Replacing it with a class X2 capacitor would be a good idea too.
It wouldn't fail as a short-circuit, which could be a pretty bad thing here if your inverter is not well protected against short-circuits.
