I am trying to find a source for this connector. It is a 3 wire 0.1" spacing connector that fit into a 3 pin header. Note the extra plastic at one end that is used to key the connector. This connector is from a European car and carries GND, +12V and a LIN bus
Edit: I measure the pitch as ~0.1". Possibly it can also be 2.5mm.
Thanks,
Z.
