Greetings!
I am trying to work on my guitar to try and make it more versatile. I got this schematic from a website. I just don't know how to apply it to the actual wiring. Someone also tried providing me with a wiring diagram of it but it doesn't seem to be working as it should, so I need help if you can point out things that are wrong on the diagram compared to the schematic, or if you can make it more efficient.
Basically, I have a 2 humbucker pickup guitar. I want to install a superswitch:
https://www.stewmac.com/articles-and-video/online-resources/learn-about-guitar-pickups-and-electronics-and-wiring/super-switchi1.htmland a push pull potentiometer
https://www.stewmac.com/electronics/components-and-parts/potentiometers/alpha-push-pull-pots.html to accomplish my goal, which is when the pot is pushed down, it will do the following:
Position 1 = Bridge pickup series
Position 2 = Bridge parallel
Position 3 = Each pickup as series but combined both in parallel
Position 4 = Neck parallel
Position 5 = Neck series
When the pot is pulled up, it would do the following (it doesn't matter to me if the position number is 1 to 5 in order or reversed on these):
Position 1 = Outer coils series
Position 2 = outer coils parallel
Position 3 = Outer coils in series, in parallel with the inner coils in series
Position 4 = Inner coils in parallel
Position 5 = Inner coils series
This would give me 10 tones instead of just the normal 5.
Please, any help would be great! I appreciate it! Let me know if there is any information that you need from me. Thanks again!
