Author Topic: GSM/GPRS module +CME ERROR: http need relocation (error code 3829)  (Read 6693 times)
Offline txescientistTopic starter
  • Country: cs
Can someone please explain me what this error means:  +CME ERROR: http need relocation.
I'm getting it after using AT+QHTTPPOST command on Quectel M95 GSM module.
« Last Edit: July 10, 2016, 11:23:53 am by txescientist »
The following users thanked this post: festevao
Offline festevao
  • Country: pt
Re: GSM/GPRS module +CME ERROR: http need relocation (error code 3829)
« Reply #1 on: September 05, 2016, 10:03:25 am »
I'm having that same error. Have you figured it out?
Offline SL4P
  • There's more value if you figure it out yourself!
« Reply #2 on: September 05, 2016, 12:15:28 pm »
Without knowing the specific module, I'd guess the GPS receiver doesn't have enough signal/satellite coverage to acquire a fix.
The docs should explain the message.
Don't ask a question if you aren't willing to listen to the answer.
Offline festevao
  • Country: pt
« Reply #3 on: September 07, 2016, 11:26:48 am »
I don't think that's the issue. Using AT+CSQ (signal quality) I get that the RSSI = 29, which is excellent
Offline SL4P
« Reply #4 on: September 07, 2016, 12:20:25 pm »
Isn't CSQ only the GSM/GPRS signal level?
Offline festevao
  • Country: pt
« Reply #5 on: September 08, 2016, 03:40:39 pm »
yes, which is the only signal that matters for making HTTP requests. GPS is not relevant
Offline Wilksey
« Reply #6 on: September 08, 2016, 03:51:18 pm »
Does it happen on a particular website?
It might relate to a 300 response code, can you see the raw header coming back?
Offline SL4P
« Reply #7 on: September 08, 2016, 09:15:40 pm »
oops.  I looked past the QHHTPPOST, and only saw GSM in the first post!   :palm:
Offline SusmitSen
  • Country: in
« Reply #8 on: August 09, 2017, 07:45:37 am »
I am also using Quectel M95 and got the same error code (3829) "http needs relocation" after trying to post data through AT+QHTTPPOST command. This seems to be some problem with the server side coding. I had no problem posting data to http://posttestserver.com/post.php. But I got this error when I used my own webpage which puts posted date into a mySql database. However, when I checked the data base, the posted data was nicely sitting there. Thus, while the POST is successful, the modem returns an error. I wonder, how to get around this problem. Any idea, anyone?
Offline Wilksey
« Reply #9 on: August 09, 2017, 03:50:54 pm »
I suspect you need to tell the "client" to re-locate when post is complete, i.e. navigate to a "success" page.
