Author Topic: Why would an isolation transformer add noise to the waveform?  (Read 3558 times)
Offline sprokTopic starter
« Last Edit: October 11, 2017, 07:30:04 pm by sprok »
Online ataradov
    • Personal site
Re: Why would an isolation transformer add noise to the waveform?
« Reply #1 on: July 23, 2016, 12:29:43 am »
It is possible that you are reaching core saturation. Saturation usually does not look like this, it typically affects shape of the slopes, not peaks.
Alex
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: July 23, 2016, 12:36:46 am »
Hmm, the combination of leakage inductance and filter capacitance may be making a resonant circuit, that's being excited by your mains' flattened tops.  Or put another way: your mains voltage contains a small amount of higher harmonics, which are being magnified by a resonant filter.
Try a 1uF film cap in series with a resistor of 10-100 ohms, placed across the terminals.  Does that dampen it?
Seven Transistor Labs, LLC
Offline System Error Message
« Reply #3 on: July 23, 2016, 03:06:57 am »
The circuit you measure is the secondary of the transformer. Since you connected it to ground and the oscilloscope is usually grounded as well, a loop can be formed or signals can also travel to ground. Some circuits filter noise by grounding so your oscilloscope picks out the noise from ground.
Offline Delta
« Reply #4 on: July 23, 2016, 03:14:37 am »
Are you sure that capacitor is directly across the secondary?
7uF across 125VAC will allow 0.33A to flow!  :scared:
Offline Arjan Emm
« Reply #5 on: July 23, 2016, 06:41:44 am »
Maybe the isolation transformer was intended for a specific inductive load. In that case they may have added the capacitor to compensate for that and improve cosine phi with it.
Offline BravoV
  • +++ ATH1
« Reply #6 on: July 23, 2016, 01:55:07 pm »
Abit off topic, but I guess its still related.
I can see you used old CRO to measure mains voltage, interested on how or what probe did you use to get those results ?
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #7 on: July 23, 2016, 03:15:28 pm »
Just a cheap Chinese 100mHz probe P6100 using 10X mode... possibly unsafe but I'm no pro.
we can understand case insensitive typing out of laziness but since H is capital....
mHz = milliHertz
MHz = MegaHertz
