Author Topic: Hydra Meter - Open Source Electronics Multimeter  (Read 764 times)
Offline EEVblogTopic starter
« on: December 26, 2024, 09:22:31 pm »
Open source multimeter project:
Offline Simmed
  • Country: nu
  • im not not not from Niue nor Mongolia
Re: Hydra Meter - Open Source Electronics Multimeter
« Reply #1 on: December 26, 2024, 09:31:42 pm »
no more turning dial ranges
a quick flip
 :popcorn:
The Niue Star is a monthly Niuean newspaper. Its founder, owner, editor, journalist and photographer is and has always been Michael Jackson.
Offline rteodor
« Reply #2 on: December 26, 2024, 09:42:16 pm »
« Reply #3 on: December 26, 2024, 09:48:09 pm »
Also mentioned here: https://www.eevblog.com/forum/oshw/hydra-meter/
Oops. Will probably get more traction in the test equipment section here.
Offline SiliconWizard
« Reply #4 on: December 26, 2024, 09:48:18 pm »
I'll put a link to the repo here: https://github.com/jduffy105/HydraMeter_0.4
(it's also in the other thread)
Offline coppercone2
« Reply #5 on: December 27, 2024, 12:41:25 am »
I did not look through schematics and designs yet but I think a good feature would be to add a solder pad to attach a 'finger' to, so if you make it, and use some kind of shield like paint, tape, plating or just metal panel, it can ground to a good point on the PCB. It might get rid of issues that are likely to arise from walki talki and stuff like that. Its a zero cost feature (for the PCB) that can potentially save some users alot of trouble.
Most meters at least have a spring finger and a small metal sheet in them to act as a partial shield on the back cover.
fluke often has some version of this
https://lh4.googleusercontent.com/-7XFkS10TFfY/VE7yZJFR3zI/AAAAAAAAAPw/Yq-aHcAMank/w762-h572-no/04.JPG
They will just have a springy metal piece soldered to the PCB that touches it when you close it up
https://www.eevblog.com/forum/testgear/fluke-179-teardown-photos/
it was added to some meter because they were acting funny around VHF. I suspect it might be a common problem for similar class of electronics.
« Last Edit: December 27, 2024, 12:49:26 am by coppercone2 »
