Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
Seeking Advice on Pull-up Resistor Values for LTC4417 VALID Pins
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Seeking Advice on Pull-up Resistor Values for LTC4417 VALID Pins (Read 256 times)
KarthiAru
Newbie
Country:
on:
December 27, 2024, 01:44:03 am »
Hello everyone!
I'm currently working with the LTC4417 to manage power switching between batteries and USB in my circuit. I've noticed that the datasheet's application circuit recommends using 1M ohm pull-up resistors on the VALID pins, which seems unusually high. Does anyone have insights on why this specific value is recommended? If you've used this component, what pull-up resistor values did you choose? Any guidance or experiences shared would be greatly appreciated!
Logged
moffy
Super Contributor
Country:
Re: Seeking Advice on Pull-up Resistor Values for LTC4417 VALID Pins
Reply #1 on:
December 27, 2024, 03:41:54 am »
I would assume that the high resistor values are chosen for efficiency reasons, but would ultimately depend on the load they are driving i.e. the /valid signal.
Logged
KarthiAru
Newbie
Country:
Reply #2 on:
December 27, 2024, 03:49:09 am »
Thanks. The /valid pins are directly connected to the STM33 MCU GPIO ports in my case.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
