One thing I want to include in my designs is a current limiting circuit for my on board power supplies. This is because I want to string a bunch of modules together (think home automation) and I don't want a short circuit starting a fire.
In the past I've used polyswitches for this job but I find them lacking - time to tip can be measured in seconds for a 200% over load for example.
Anyway, I've attached an image of the circuit I'm playing with.
The MOSFET I'm using as a pass element is an NTD2955PT4G (datasheet here:
http://www.mouser.com/ds/2/308/NTD2955-D-90147.pdf)
Rated at 12A and 60V, I guessed that it would be fine at 500mA from a 15V rail. (Guessed, yes. No maths was harmed in this experiment. This was probably my first mistake).
I built my circuit, and hooked it up to my copy of Dave's constant current load. This I limited to 800mA, and confirmed by running the power supply under test (through my ammeter) into the load. Adding my current limit circuit in series, the current indeed was limited to around 500mA, and I thought I was successful.
Until I noticed that the solder around my FET was re-flowing nicely. Very, very hot.
I was assuming that when current limiting, the BC807 would turn the FET off, but that's a bad assumption. It *limits* the FET - I measured the gate voltage to be around 9V, not near 15V and thus the FET (I assume) is in a linear mode of operation, and is dissipating around 7.5W (15V * 500mA) of heat.
1. Would you agree that this assumption is true?
2. Could some one suggest an improvement so that my circuit indeed switches the FET off, rather than limit current through it?In an ideal world this switching action would turn the ET back on when the fault condition / current over load is removed.
Not that if I pull the gate up to 15V the FET does turn off.
I could 'solve' this by using a large heat sink, but that adds both cost and size to my project.
At least this experiment has allowed me to define my requirements for this circuit - I don't need a current limiting circuit, rather I need a resetting electronic fuse. I think...
Thanks for any comments.
