Author Topic: Help needed with IC substitution problems......  (Read 1242 times)
Online TERRA OperativeTopic starter
  • Country: jp
  • Voider of warranties
    • Near Far Media Youtube
« on: November 23, 2019, 08:04:56 am »
I'm currently building a DC Bias Option board for my HP 4276A LCZ meter and I am having a little trouble with substituting the old, obsolete and expensive LF13331D Analogue Switch with an in production (and substantially cheaper) TC4066BP Analogue Switch.
I'm sure there's something basic that I am missing here, but I've come to a blank trying to get this to work.
When I made this circuit with the LF13331, it worked perfectly but with the same circuit adjusted to use the TC4066BP, it's just not working..
Basically, every time I plug the TC4066BP on, it pulls the 6.3V rail right down, even if I leave the control pins disconnected.
I've included the original and new schematics below, along with datasheets of both parts. If someone smarter than me can take a look and tell me what I'm doing wrong, that would be greatly appreciated. :)
The first attachment is my revised schematic, the second is the original HP schematic.
« Last Edit: November 23, 2019, 08:07:22 am by TERRA Operative »
Offline Jay_Diddy_B
Re: Help needed with IC substitution problems......
« Reply #1 on: November 23, 2019, 08:23:13 am »
I can tell you what is wrong. It may take a little while to come up with a solution.
The original part LF13331 was powered from +/-12V
The TC4066 is powered from +12V and ground.
The TC4066 is limited to 20V max operation.
The switch pins have to be inside the rails for the switch to work.
In your design you are shorting the 6V3 rail to ground through substrate diodes in the TC4066.
Regards,
Jay_Diddy_B
Online oPossum
« Reply #2 on: November 23, 2019, 08:34:11 am »
DG412 may work as a substitute for the LF13331.
https://www.vishay.com/docs/70050/dg411.pdf
Offline Jay_Diddy_B
« Reply #3 on: November 23, 2019, 08:38:32 am »
I was going to suggest ADG444. Similar to oPossum's suggestion.
Power with +/-12V and 5V on Vlogic
Jay_Diddy_B
The following users thanked this post: oPossum, TERRA Operative
  • Country: jp
« Reply #4 on: November 23, 2019, 08:45:35 am »
Aaahh, I knew the devil was in the details somewhere.... :D
Thanks for the info, I'll take a look at those suggested substitutions and see what ones I can get easily here.
Offline German_EE
« Reply #5 on: November 23, 2019, 08:47:04 am »
Why not power the 4066 with +/- 6.3V from either side of the zero adjust control?
Warren Buffett
Offline Jay_Diddy_B
« Reply #6 on: November 23, 2019, 08:54:16 am »
Good idea, but...
The control pins are driven by 0-5V logic signals
The thresholds on the TC4066B are with respect to VSS. You would have VSS at -6.3V.
You would have to level shift the control inputs.
Other switches like the ADG and DG family have the level shifter built in.
Jay_Diddy_B
