Author Topic: Inductor selection for DC/DC  (Read 2593 times)
Offline atwozTopic starter
« on: July 01, 2012, 07:52:55 pm »
Hello,
I'm designing a DC to DC converter, 12v to 5v @ 300mA. I need a 10uH inductor for the job. I was using some big power inductors but I think its overkill and that I could use a smaller inductor.
What do you guys think of the following inductor?
http://www.newark.com/taiyo-yuden/cbc3225t100mr/power-inductor-10uh-760ma-20/dp/30K5409?in_merch=Popular%2520Inductors,%2520Chokes%2520And%2520Coils
Thanks!
Offline T4P
  • Country: sg
    • T4P
Re: Inductor selection for DC/DC
« Reply #1 on: July 01, 2012, 08:10:43 pm »
If you only need less then the SRF then of course everything's good
Offline free_electron
    • SiliconValleyGarage
« Reply #2 on: July 01, 2012, 08:11:18 pm »
without knowing what controller chip you are using , or at least what switching frequency , mode (hysteretic , constant current, contstant on time ) we cannot advise ...
« Reply #3 on: July 01, 2012, 08:43:37 pm »
Sorry, the controller is the NCP3170A (from ONSemi) and it runs at 500kHz.
« Reply #4 on: July 01, 2012, 09:45:51 pm »
ideally you would use a 4u7 part with that thing. i'd stick in a vls3012 or vlf4010 series from tdk.
the taiyo you selected will work too. the only thing i don't like about the taiyo is that it is a non-shielded coil. the TDk's i gave above are shielded
Offline szhighstar
  • Country: cn
« Reply #5 on: July 01, 2012, 10:40:49 pm »
if rate current can meet your requirement, you can select, we can also make the chip inductor.
