Author Topic: A classic power amplifier from the 80's. What a beauty!  (Read 12707 times)
Offline KhronX
    • Khron's Cave - Electronics Blog
Re: A classic power amplifier from the 80's. What a beauty!
« Reply #50 on: April 07, 2018, 02:30:12 pm »
A few weeks ago, my girlfriend got her mits on a freebie Yamaha AX-930 from the early 90s, "on my behalf"  :-+ (ie. sent me a photo of it and asked if i wanted it  :-DD )
For once, the <ahem> "marketing wank" might be considered as being in the ballpark of honest advertising  ;D
Specs & co: http://www.hifi-wiki.de/index.php/Yamaha_AX-930
Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
Offline taydinTopic starter
  • Country: tr
« Reply #51 on: April 07, 2018, 04:06:05 pm »
Wow that thing must have been running in an isolated environment with air filtering :O No dust and rat piss at all ...
Real programmers use machine code!
My hobby projects http://mekatronik.org/forum
Offline KhronX
« Reply #52 on: April 07, 2018, 04:16:43 pm »
Maybe not visible in the photo, but it did have a little bit of spider-web in the rear right corner, and a couple dead bug corpses under the front panel, but all in all, not bad for over a quarter century, indeed  ;D
  • Country: tr
« Reply #53 on: September 07, 2018, 11:18:59 am »
Finally got around working on my classic amp. I borrowed a wire wrapping tool so that I can restore the amp in its original condition.
And then I started assembling the PCB's to the frame
And finally re-did all the wire wrapping
  • Country: tr
« Reply #54 on: September 07, 2018, 11:28:00 am »
The unit was now in a state where I could power it up and apply a test signal. I did this and I was getting no output.
I had already found the schematic of this unit. Checked the power rails, all were good. Started tracing the signal from input into the amp and found out that the pre-amp doesn't output anything. The pre-amp was not getting 24V power.
I following the pre-amp power to the main power supply, and, not surprisingly, the BD135 that was removed and mounted to the chassis was a single transistor regulator, obtaining 24V from +40V. And it was bad. The schematic says that it is a 2SC1449 and the closest equivalent that was available here was BD377. So I replaced it with that and also inserted a small heat sink.
Re-tested after installing new transistor, and I was getting output from the amp!
  • Country: tr
« Reply #55 on: September 07, 2018, 11:30:16 am »
Testing the repaired unit with a spotify media player, which is another project I'm working on.
I remember this amp having a great sound, and I was really pleased to hear it after this long. I love it ;D
« Last Edit: September 07, 2018, 11:34:55 am by taydin »
