Author Topic: Graphs won't be plotted to the end of simulation time in Simulink  (Read 352 times)
Offline cadenaTopic starter
Hi everyone,
I am having the issue that I am trying to run an FOC algorithm in Simulink (see image attached) but the graphs are plotted until 0.5 when the simulation is set to 10 seconds (see image attached). Does anyone know what could be happening ? Thanks in advance.
The file can be found in the following MatlabExchange link:https://es.mathworks.com/matlabcentral/fileexchange/39605-vector-control-of-permanent-magnet-synchronous-motor-pmsm
