Author Topic: Help to identify a SOT23-6 from its marking?  (Read 768 times)
Offline Romain
« on: February 15, 2018, 09:49:19 pm »
Hi
I'm trying to fix a LCD driver board. It's a LCD kit I bought and I do not have any datasheet nor schematic with it...
One of the power supplies capacitors is microphonic and the noise is just terrible  :palm:
At first I tried to swap the 1µF capacitor with a new 4.7µF capacitor but it made the matter worse. I'd like to get to the bottom of this, and have a look at the converter's datasheet.
The component is most likely a Buck converter converting the 12V in to 9V out, probably driving the LCD backlight.
The device marking is "W659".
Anyone who could help me with that?  :-+
Offline sstepane
  • Country: ua
Re: Help to identify a SOT23-6 from its marking?
« Reply #1 on: February 15, 2018, 10:43:12 pm »
I do usually check the sites for smd markings:
http://www.s-manuals.com/smd
https://www.semicon-data.com
http://kazus.ru/datasheets/smd/index.html
http://www.smdmark.com/en-US/smd-code-fd2.html
There are some more sites if You google with smd markings.
However, another very good source for smd markings is taobao. I would search like "W659 SOT23-6" or what is chip packages size and if it sells there - there will be partnumber.
Hope it helps. It did many times for me.
Offline Romain
« Reply #2 on: February 17, 2018, 07:16:06 pm »
Thanks sstepane. I could not find anything on the websites, but I'll keep them for future reference  :-+
I found a drop-in component on Mouser : https://www.mouser.com/ds/2/115/AP3211-271560.pdf
I'm almost certain that it's not the exact same one, but probably close enough to start tinkering with ! :-/O
