Author Topic: Help me cross-ref this relay?  (Read 256 times)
Offline iXodTopic starter
« on: March 05, 2023, 03:33:15 pm »
This Panasonic automotive relay is NLA:
https://media.digikey.com/pdf/Data%20Sheets/Panasonic%20Electric%20Works%20PDFs/CQ_Relays_ACQ.pdf
I can’t find a replacement with equivalent rating (25A inrush—preferably higher; these relays failed at a spectacularly high rate). I mean, I can’t find a replacement that isn’t a Chinese “ignition source”.  :(
The markings on the relay are “CQ1W-12V-H24”. “W” is apparently for a wiper motor load. Can’t find a reference to “H24” in any Panasonic literature.
There is vertical room for a taller replacement.
Any help would be greatly appreciated.
Cheers!
