Hello all. I did a little searching on the forum to make sure i post this in the right place, so I hope that is here.
I have a small project that requires some electronics skill. I am personally at a deficit of the required skill set so I’m reaching out to the EEV community.
I am building a prototype that involves a device that reports a position to a two digit numerical display. As the position changes the numerical display has to instantly change to update the new position. It is battery operated.
So it has a read head or sensor head that moves along a strip of pre-defined positions, and the second component with the LCD readout that also houses a battery compartment.
I need someone who can create schematics that can be submitted to manufacture for the required PCB’s.
If anyone is interested in a side job please message me and we can arrange to go over more details. I have drawn up some rough schematics that will shed more light. Also, I don’t have much of a budget to work with, so this will probably not be the job that pushes the retirement plan over the top.
Thanks!
