Author Topic: Part identification  (Read 364 times)
Offline gaminnTopic starter
Part identification
« on: November 20, 2023, 11:53:56 am »
any idea what's this (part number)? Thanks
Offline Zero999
  • 0999
Re: Part identification
« Reply #1 on: November 20, 2023, 05:48:35 pm »
It looks like a diode.
What device was it taken from?
Offline DavidAlfa
« Reply #2 on: November 20, 2023, 06:20:25 pm »
NR = SMBJ75A TVS diode, unidirectional, 75V, datasheet.
« Reply #3 on: November 20, 2023, 08:34:32 pm »
Thanks. My diode tester shows 0 V for both directions of the TVS and ohm meter shows exactly same value in ohms for both directions of the TVS. Depending on TVS it shows from 3 to 20 ohm. So I guess they are all destroyed, right?
Offline Zero999
  • 0999
« Reply #4 on: November 20, 2023, 08:55:30 pm »
If it conducts in both directions, under its rated voltage, then it's bad. It's highly it's not the only bad part: many other components will have been destroyed.
