Author Topic: Help with a Buck Transistor  (Read 2756 times)
Offline AtomAmpTopic starter
« on: November 19, 2013, 04:42:08 am »
Somewhere I saw a schematic of a Buck transistor.  I can't for the life of me find it again or remember where I saw it.
It would go in this order: 18v 1a ac to a 1a bridge rectifier to a capacitor to the transistor,(not a dip. Simple 3 pin trans.) to another capacitor and
end up with 12v to feed a fan running at 12v 0.07a
I can't remember which transistor they used or the size of the caps.
Can anyone help?
Thanks...
Offline Jon86
Re: Help with a Buck Transistor
« Reply #1 on: November 19, 2013, 06:49:43 am »
Do you mean a voltage regulator?
Death, taxes and diode losses.
Offline kxenos
  • Country: gr
« Reply #2 on: November 19, 2013, 06:59:39 am »
I think this is the buck transistor (!)you want http://www.farnell.com/datasheets/1696820.pdf  ;D
Offline Dragonfly
« Reply #3 on: November 19, 2013, 07:03:08 am »
I agree. I sounds like you are looking for the LM7812.  Here's a reference schematic similar to the one you described.
http://schematiccircuit.com/12-volt-power-supply-lm7812/
« Reply #4 on: November 19, 2013, 07:11:16 am »
My apologize. Yes, I am speaking of a voltage regulator.
The transistor that I saw was a 3/4 round, flat top, 3 pin, E,B,C  I believe is a TO-92  I think it was a PNP.
« Reply #6 on: November 19, 2013, 06:33:39 pm »
Yes Dragonfly,  just like that!
you're the best.
Thank you, thank you all for your help!
Now I can get back to work...
