Ok i did some research.
I am going to go either with modified kit or
Elektor 1982 design.
What do you think of Elektor 1982 design ?
Only thing is i would need either a separate power transformer or wind some low power windings on my transformer for that 2x12v that is needed for the Elektor design.
What about the pcb? Is there some design already out there?
The Elektor 1982 is not a bad circuit. I did build one once and sold it for good money.
You should think right now about some options, like switching ranges for the instruments, sense int/ext, etc.. also, if you get an separate transformer for the auxiliary supply, have another voltage on it for control and instrument lights (if analogue) or separate panelmeter supplies. Do not use those crappy panelmeters that claim to work as well without one!
With a separate transformer, you could use a relay or SSR for the main transformer and switch it only on if the auxiliary voltage(s) is up and good. Also, the circuit lacks thermal safeties, which you could also wire into this circuit.
Place at least 2 thermal switches between the transistors and maybe one with the rectifier and 1..2 on the main transformer. With really simple circuits like a small additional relay you could also have an indicator for overtemperature. It is not among the most efficient ones as it lacks a pre-regulator, but that makes it easy to understand and modify.
Use really good, precision, inductance free resistors in the power circuit (emitter res. too). Be aware that you can easily switch the A-meter range, but not the current adjustment. In that case you would have to use a circuit which does not interrupt the current shunt (ring-shunt switch).
The thread discussing this PS circuit here on the forum sems to have covered some of those options, although in a more electronic implementation. Some other improvements as well.
Not the worst choice.
