Author Topic: Help with extension connector used by JBC in equipment DI-1 DE-2 DME-4  (Read 2348 times)
Offline netandinoTopic starter
  • Country: pe
  • Téc. Comp. e Informática Téc. Electrónica Ind.
    • Net Andino
Good morning colleagues, I'm doing my station controllers for HAKKO and JBC, here is the driver example for 140W hakko that I made "is in Spanish" https://netandino.blogspot.com/2019/01/control-de-temperatura-para-cautin-con.html
Now I am with a doubt since I do not know which connector are these of JBC and I have a question for you, I hope you can help since I need to know the name and / or characteristics of the connectors used by JBC for extension of the JBC DI equipment. 1 DE-2 DME-4, attached images for more details
regards
Soluciones en Electrónica, Informática y Refrigeración
  • Country: pe
    • Net Andino
Re: Help with extension connector used by JBC in equipment DI-1 DE-2 DME-4
« Reply #2 on: February 01, 2019, 08:13:34 pm »
Hi, I searched for information on the link but there is information, just talk about the pins. I want the name and model of this connector.
that to use my bases or JBC stand with its original cables.
I have this stand  DN-SE https://www.jbctools.com/dn-se-stand-for-t210t245t470-na-product-1183.html
conector for:  Stand extension cable Ref. A1286  https://www.jbctools.com/a1286-kit-extension-lead-product-135.html
Offline tsman
« Reply #3 on: February 01, 2019, 08:18:02 pm »
The connector on the station side is a binder series 678, Farnell order number 1122401.
You can see the Binder B logo on your connectors.
  • Country: pe
    • Net Andino
« Reply #4 on: February 02, 2019, 02:18:33 am »
Thanks for your support, I found the connector with these dates:
* Binder, 7 Pole Panel Mount Miniature Connector Socket, Female Contacts
* BINDER - 99 0622 00 07 - SOCKET, FREE, 7WAY , 678 SERIES
