Hi there,
The following photos are from a car injection unit on a 1995 european Peugeot 205 car. On these cars this injection unit is incorporated into the throttle body. So, it is a single point throttle body injection unit. Some Peugeot 205 models have a Bosch injection unit but this one is from Weber. I do have the TU1M engine. Maybe useful info for people familiar with these cars.
I would like to know the name of two connector systems used on this injection unit.
Connector system A
Please see photo 1. The attached dimensions are in mm. The spacing between the terminals is 3.4 mm. But that was with manual measurement it could also be 3.5 mm or so. It looks a bit like TE Superseal but notice the mushroom shape with makes this one different.
Photo 2. There are also 3 and 4 terminal versions of this connector system on this injection unit. Same terminal spacing.
Connector system B
Photo 3. On the bottom of this one there is the AMP logo, so it should be a TE product now. I hope they still make this connector system. The terminal spacing is about 5.2 mm and on top there is text that reads “SONOCAS 6”. I wasn’t able to find anything on this text with an internet search.
Well, the chore of posting this was quite boring. But I would still be excited if someone can point me to any of these connector systems!
Have a nice day,
Zeyneb
