Author Topic: Where to buy small 4wire slip-ring with built-in pot or position sensor  (Read 1497 times)
Offline PsiTopic starter
Hey guys, i'm trying to find a small slip ring which provides 4 contacts as well as position information about the rotation.
Doesn't really matter how the rotation sense is done internally but i would much prefer an absolute value as opposed to being relative to start position. A continuous rotation pot would be ideal.
Size doesn't matter to much, but ideally smaller than 4cm width wise.
Anyone seen something like that for <US$30 ?
Or, failing that, does anyone have ideas for getting position from a slip ring externally which would be easy to do mechanically?
Best way i can think of is a magnet and hall sensor, time each revolution using a micro and calc the angle assuming constant speed.
« Last Edit: October 17, 2013, 06:15:40 am by Psi »
Re: Where to buy small 4wire slip-ring with built-in pot or position sensor
« Reply #2 on: October 17, 2013, 06:13:51 am »
yeah, i know you can get slip-rings on ebay. I'm looking for one with a built-in continuous rotation potensiometer.
