Thank you.
In your example, you are dividing 24v down to 5.5v (100k and (30k in parallell with 100k))
I expect that R1 should always be = R3 and R2=R4 - but wonder if that is correct?
1: It means that the opamp (as connected above )could be driven by only 6v, and work?
I see that I will need different voltage divider resistors (R1,R5 and R6,R3) to properly scale let's say 8.4volt
I also wish to get to 0..3.2v output - driving the opamp of 3v3.
2: Is there any meaningful difference in the two following approaches:
- each opamp could have a fixed divider that scaled it's highest voltage down to 3v(on inpouts) , and all have the same gain.
- all opamps use resistors that makes the highest cell be within 3v(on inputs) , - and the gain is set differently for each to have the output reach 3.1v (at 4.2v input difference.)
I expect to do software calibration, so as long the output is linear, minor variance due to nearest resistor value/tolerances etc won't matter.
