Well, not the best capacitors used on it, and they probably will fail in a year, but otherwise looks reasonable, and for the price quite good. Just treat the ratings as an absolute max, and run at roughly half the current and with lower voltage input. You probably will change them if you want long life, and at least they do include a fuse for safety.
