Pqass,
I found the LiquidCrystal with the library manager set to installed. The name was just 'LiquidCrystal' (no .h)
I got rid of the I2c, and put .h, and the compiler went past it to the reference an then errored out:
Arduino: 1.8.19 (Windows 7), Board: "Arduino Pro or Pro Mini, ATmega328P (5V, 16 MHz)"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Paul\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Paul\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries D:\Users\Paul\Documents\Arduino\libraries -fqbn=arduino:avr:pro:cpu=16MHzatmega328 -vid-pid=10C4_EA60 -ide-version=10819 -build-path C:\Users\Paul\AppData\Local\Temp\arduino_build_342850 -warnings=none -build-cache C:\Users\Paul\AppData\Local\Temp\arduino_cache_749214 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Users\Paul\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\Paul\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.arduinoOTA.path=C:\Users\Paul\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\Paul\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avrdude.path=C:\Users\Paul\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\Paul\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -verbose D:\Users\Paul\Documents\Arduino\sketch_millivolt_1\sketch_millivolt_1.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Paul\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Paul\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries D:\Users\Paul\Documents\Arduino\libraries -fqbn=arduino:avr:pro:cpu=16MHzatmega328 -vid-pid=10C4_EA60 -ide-version=10819 -build-path C:\Users\Paul\AppData\Local\Temp\arduino_build_342850 -warnings=none -build-cache C:\Users\Paul\AppData\Local\Temp\arduino_cache_749214 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Users\Paul\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\Paul\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.arduinoOTA.path=C:\Users\Paul\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\Paul\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avrdude.path=C:\Users\Paul\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\Paul\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -verbose D:\Users\Paul\Documents\Arduino\sketch_millivolt_1\sketch_millivolt_1.ino
Using board 'pro' from platform in folder: C:\Users\Paul\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5
Using core 'arduino' from platform in folder: C:\Users\Paul\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5
Detecting libraries used...
"C:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\eightanaloginputs" "C:\\Users\\Paul\\AppData\\Local\\Temp\\arduino_build_342850\\sketch\\sketch_millivolt_1.ino.cpp" -o nul
Alternatives for EEPROM.h: [EEPROM@2.0]
ResolveLibrary(EEPROM.h)
-> candidates: [EEPROM@2.0]
"C:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\eightanaloginputs" "-IC:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\EEPROM\\src" "C:\\Users\\Paul\\AppData\\Local\\Temp\\arduino_build_342850\\sketch\\sketch_millivolt_1.ino.cpp" -o nul
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
-> candidates: [SPI@1.0]
"C:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\eightanaloginputs" "-IC:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\EEPROM\\src" "-IC:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "C:\\Users\\Paul\\AppData\\Local\\Temp\\arduino_build_342850\\sketch\\sketch_millivolt_1.ino.cpp" -o nul
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
-> candidates: [Wire@1.0]
"C:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\eightanaloginputs" "-IC:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\EEPROM\\src" "-IC:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-IC:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "C:\\Users\\Paul\\AppData\\Local\\Temp\\arduino_build_342850\\sketch\\sketch_millivolt_1.ino.cpp" -o nul
Alternatives for LiquidCrystal.h: [NewliquidCrystal LiquidCrystal@1.0.7]
ResolveLibrary(LiquidCrystal.h)
-> candidates: [NewliquidCrystal LiquidCrystal@1.0.7]
"C:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\eightanaloginputs" "-IC:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\EEPROM\\src" "-IC:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-IC:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\LiquidCrystal\\src" "C:\\Users\\Paul\\AppData\\Local\\Temp\\arduino_build_342850\\sketch\\sketch_millivolt_1.ino.cpp" -o nul
"C:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\eightanaloginputs" "-IC:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\EEPROM\\src" "-IC:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-IC:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\LiquidCrystal\\src" "C:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src\\SPI.cpp" -o nul
"C:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\eightanaloginputs" "-IC:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\EEPROM\\src" "-IC:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-IC:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\LiquidCrystal\\src" "C:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src\\Wire.cpp" -o nul
"C:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\eightanaloginputs" "-IC:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\EEPROM\\src" "-IC:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-IC:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\LiquidCrystal\\src" "C:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src\\utility\\twi.c" -o nul
"C:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\eightanaloginputs" "-IC:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\EEPROM\\src" "-IC:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-IC:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\LiquidCrystal\\src" "C:\\Program Files (x86)\\Arduino\\libraries\\LiquidCrystal\\src\\LiquidCrystal.cpp" -o nul
Generating function prototypes...
"C:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\eightanaloginputs" "-IC:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\EEPROM\\src" "-IC:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-IC:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\LiquidCrystal\\src" "C:\\Users\\Paul\\AppData\\Local\\Temp\\arduino_build_342850\\sketch\\sketch_millivolt_1.ino.cpp" -o "C:\\Users\\Paul\\AppData\\Local\\Temp\\arduino_build_342850\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\Paul\\AppData\\Local\\Temp\\arduino_build_342850\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\eightanaloginputs" "-IC:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\EEPROM\\src" "-IC:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-IC:\\Users\\Paul\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\LiquidCrystal\\src" "C:\\Users\\Paul\\AppData\\Local\\Temp\\arduino_build_342850\\sketch\\sketch_millivolt_1.ino.cpp" -o "C:\\Users\\Paul\\AppData\\Local\\Temp\\arduino_build_342850\\sketch\\sketch_millivolt_1.ino.cpp.o"
sketch_millivolt_1:50:37: error: no matching function for call to 'LiquidCrystal::LiquidCrystal(int, int, int, int, int, int, int, int)'
LiquidCrystal lcd(0x27,2,1,0,4,5,6,7); // 0x27 is the default I2C bus address (this could be different for some modules)
In file included from D:\Users\Paul\Documents\Arduino\sketch_millivolt_1\sketch_millivolt_1.ino:21:0:
C:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src/LiquidCrystal.h:55:3: note: candidate: LiquidCrystal::LiquidCrystal(uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t)
LiquidCrystal(uint8_t rs, uint8_t enable,
C:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src/LiquidCrystal.h:55:3: note: candidate expects 6 arguments, 8 provided
C:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src/LiquidCrystal.h:53:3: note: candidate: LiquidCrystal::LiquidCrystal(uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t)
LiquidCrystal(uint8_t rs, uint8_t rw, uint8_t enable,
C:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src/LiquidCrystal.h:53:3: note: candidate expects 7 arguments, 8 provided
C:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src/LiquidCrystal.h:50:3: note: candidate: LiquidCrystal::LiquidCrystal(uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t)
C:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src/LiquidCrystal.h:50:3: note: candidate expects 11 arguments, 8 provided
C:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src/LiquidCrystal.h:47:3: note: candidate: LiquidCrystal::LiquidCrystal(uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t)
C:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src/LiquidCrystal.h:47:3: note: candidate expects 10 arguments, 8 provided
C:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src/LiquidCrystal.h:45:7: note: candidate: constexpr LiquidCrystal::LiquidCrystal(const LiquidCrystal&)
class LiquidCrystal : public Print {
C:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src/LiquidCrystal.h:45:7: note: candidate expects 1 argument, 8 provided
C:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src/LiquidCrystal.h:45:7: note: candidate: constexpr LiquidCrystal::LiquidCrystal(LiquidCrystal&&)
D:\Users\Paul\Documents\Arduino\sketch_millivolt_1\sketch_millivolt_1.ino: In function 'void setupLCD()':
sketch_millivolt_1:150:7: error: 'class LiquidCrystal' has no member named 'setBacklightPin'
lcd.setBacklightPin(3,POSITIVE); // (BL, BL_POL)
sketch_millivolt_1:150:25: error: 'POSITIVE' was not declared in this scope
sketch_millivolt_1:151:7: error: 'class LiquidCrystal' has no member named 'setBacklight'
lcd.setBacklight(HIGH); // LCD backlight turned ON
Multiple libraries were found for "LiquidCrystal.h"
Used: C:\Program Files (x86)\Arduino\libraries\LiquidCrystal
Not used: D:\Users\Paul\Documents\Arduino\libraries\NewliquidCrystal
Using library EEPROM at version 2.0 in folder: C:\Users\Paul\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\EEPROM
Using library SPI at version 1.0 in folder: C:\Users\Paul\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\SPI
Using library Wire at version 1.0 in folder: C:\Users\Paul\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire
Using library LiquidCrystal at version 1.0.7 in folder: C:\Program Files (x86)\Arduino\libraries\LiquidCrystal
exit status 1
Paul
