Electronics => Projects, Designs, and Technical Stuff => Topic started by: vk3pb on December 26, 2015, 10:35:56 am
Hi Dave & all
I have a small balloon transmitter project that I am working on that needs a little advice.
Basically my plan is to build a lightweight battery powered transmitter to transmit geographic coordinates derived from a gps on an amateur radio frequency, and then launch this on a picoballoon (small balloon like you get in party shops).
To do this without needing permission or a license my payload must be less than 50 grams total!
The good news is that I have a working prototype which uses an Arduino mini, AD9850 direct digital synthesizer (dds) and Neo-6 gps. It runs well, transmitting on 10.140 Mhz however I have two problems.
The first is that the output of the AD9850 is very low - probably less than 10 mw. I need to amplify that power a little - say 10x. I also need a little filtering because the output of the dds is not so clean. I am getting output on other frequencies but at lower levels.
I have looked around the internet for circuits to achieve the above but the ones I have seen are way too complicated and more importantly - heavy. I need a simple circuit of no more than say 4 or 5 components that can be put on a small piece of breadboard and the total would weigh less than 10 grams. Can anyone help with a simple circuit that can give some amplification and a little filtering. The filtering does not need to be perfect as at these power levels no one is likely to receive the harmonics anyway.
Thanks Peter
The frequency you are using is in the 30meter Amateur radio band, and there are hundreds if not thousands designs for low power transmitters and power amps on the internet. You should be able to get plenty of power output from a single transistor stage, and you won't need any kind of exotic/expensive transistor.
Search for "30m QRP amplifier", e.g. the class C driver stage here (http://www.electronics-tutorials.com/transmitters/30m-qrp-transmitter.htm) should be more than adequate. It's also possible to use CMOS logic devices such as this design based on a 74HC240 (http://www.hanssummers.com/qrss/qrsstx.html), which also includes an output filter.
There is a useful design guide for harmonic filters here (http://www.gqrp.com/technical2.htm).
Probably need a little more information. What form of modulation are you using? A small MMIC IC amp chip should could get you a good +10db gain with little weight but the added current flow may require a larger battery capacity for the same flight time duration?
Your choice of 10MHz is rather unusual as well as probably technically illegal. Applications like this are usually line of sight VHF or UHF as antenna efficiency is much better with a higher operating frequency, but of course your DDS limits your choice to HF.
Thanks mikerj and retrolefty
I shall look at those links.
As an amateur I'm permitted to use the 30m band. The plan is to use wspr mode which means that even with a small amount of power my transmitter can be received over long distances. If combined with some Arduino sleep routines I will hopefully be able to get the batteries to last a few days.
As for modulation wspr is fsk with 6 hz bandwidth.
Cheers Peter
But doesn't using lower frequencies mean you need a physically larger antenna to achieve any decent efficiency?
Hi Peter
if you use your aprs frq on 2m vhf,your signal will be digipeted on to google maps.fi and your antanna wll not need to be so long i dont know what power you are alowed to use unatended in vk land,uk is 500mw,
i would go for 2m aprs and it has been done a lot ,so loods of info on the net and yahoo aprs groups
good luck Dave 2E0DMB
Yes, if you are operating in a covered area, APRS will provide real-time tracking.
Ref: APRS Australia: http://www.aprs.net.au (http://www.aprs.net.au)
Example: Sydney area: http://www.aprs.net.au/live/sydney-area-interactive-aprs (http://www.aprs.net.au/live/sydney-area-interactive-aprs)
You are correct that one can use APRS on 2m to send positional data into the aprs network but one you go out to sea you can't track the balloon any more. Although hf requires a larger antennĂ it can be used with wspr to send data over very large distances.
Cheers Peter
How far out to sea are you talking about? I see many maritime stations being tracked on the aprs.fi website.
If you are so budget-constrained on weight, how do you expect to deploy an efficient HF antenna? Of course, since you have not revealed your location, we have no idea what the APRS coverage is in the area of interest.
