Hi Everyone,
I've been playing around with Grant Searle's CP/M on FPGA project:
http://searle.hostei.com/grant/Multicomp/index.html...and learning / changing the VHDL at the same time. Right now it is a mess of a EP2C5T144C8N development board and a breadboard with sram, serial, ps/2, and vga connectors on it.
I was thinking about making a single board that has everything on it, or perhaps a plug on board that plug onto the development board to add the sram and ports.
Then I was thinking what about an integrated video/keyboard? I know it wouldn't be the best keyboard, but I really love standalone handheld gadgets and I've already done a smaller keyboard for the microenigma I built:
So my first question is instead of VGA output which is what Grants project has, would it be fairly easy to modify the VGA output into RGB output for a 4.3" TFT ? They seem to need to be refreshed just like VGA does, but perhaps with different timing.
I would have to figure out which keys are necessary on a CP/M keyboard to make sure my keyboard included them. Obviously control, shift, enter, capslock, but I suppose I'd have to look at several popular CP/M systems and see what keys they supported.
I've already modified the project to have a concurrent vga/ps2 with serial so it outputs to both and accepts input from both.
I would need to work on the full support of ansi/vt100 sequences which I wonder if would be better implemented in the CP/M bios instead of vhdl, but that would be something else to think about.
It, like most projects, seems like a lot of work, but I wonder if it would be cool/worthwhile in the end. Would a single board with a tactile button keyboard and 4.3" TFT display be something cool to work on/play with? You could always connect it to a larger terminal over serial. Thinking out loud here!
What do you guys think? Any other thoughts or ideas?
