There are several ways to skin a cat, and as such when you ask the question, you'll receive several differing answers.
Personally, I like Randy222's higher-source voltage the best. It could be 24V source voltage as suggested, or it could be 12V source voltage.
Cameras may not consume much during regular operation. But at night, when the IR LEDs light up, the current consumption increases significantly.
And of course, if the camera has a tilt and pan operation, the consumption will increase even further.
In theses circumstances, to avoid voltage drops on long runs which could cause nuisance resets, it is better to run at a higher source voltage.
