Author Topic: High efficiency voltage converter out of MOSFET driver.  (Read 510 times)
Offline MasterTTopic starter
« on: March 02, 2019, 03:57:51 am »
Design idea, getting step-up or inverter converters out of MOSFET driver IC.
Despite commonly used topology using switch + schottky diode as a rectifier, here is another concept, one side of the MOSFET driver served as a switch, but another side as synchronous rectifier - zero lost power. Schottky diodes are there just for initial start-up.
 Only step-up converter proof of concept tested so far.
