Author Topic: DIP chip footprint vs DIP socket footprint. PCB making problem ...  (Read 3344 times)
Offline redbenTopic starter
Hi, I have a simple question:
Does socket for DIP package have the same mechanical properties as the chip itself ??
I have sockets lying around that I don't have the data sheet and I want to use them in my design.
If I use the standard DIP footprint of my chip, will the socket fit in that footprint ?
And my socket has rigid leads :(
I could print out on paper to try, but if someone has any infos it would be very very helpful.
Sorry for the english mistakes ...
Online Alex Eisenhut
  • Place text here.
Re: DIP chip footprint vs DIP socket footprint. PCB making problem ...
« Reply #1 on: November 02, 2014, 02:39:10 pm »
If by properties you mean distances, yes, it should. You have Augat machined sockets?
Or longer leads? Then it's a wire-wrap socket. You can still solder to them, just clip off the extra length.
But are you making your own PCB? Then you don't have plated-through holes, so only use the bottom for connections, otherwise you have to solder on both sides of the board.
Offline westfw
« Reply #2 on: November 03, 2014, 03:01:31 am »
A DIP socket extends slightly beyond the holes, while a DIP package fits fully inside the hole pattern (except sometimes lengthwise.)  This shouldn't matter for most PCB designs, but it is possible to design a PCB for chips that won't work with sockets.
In the other direction, I've seen people put crystals and other components underneath a chip, where the sockets they are using happen to have empty space.  So you can also design a PCB that works with sockets, but not without.
Offline sleemanj
  • Professional tightwad.
« Reply #3 on: November 03, 2014, 03:58:31 am »
Measure twice, make PCB once.
A set of digital calipers is very useful for the PCB designer to have on their desk, 10 seconds and you can accurately measure the thing to make sure.
« Reply #4 on: November 05, 2014, 03:39:41 pm »
Thanks for all the answers, That helped me figure it out.
I finally made the effort to print it first on paper to make sure everything fits correctly enough.
After some trouble to print it 1:1 My conclusion is :
- it might be slightly too wide, but it still fit (I am talking 1/10 of a millimeter or there about).
Nothing to worry about.
