Author Topic: where to buy 27pin ribbon cable from molex  (Read 555 times)
Offline roffelkartoffelTopic starter
« on: October 27, 2021, 07:50:23 pm »
lHi,
currently I'm "developing" a mechanical keyboard wich should be driven by a Logitec multi device pcb salvaged from an old K375s board. The Logitech board uses plastic sheets as "pcb" and seems to be connected via a 27 pin, 1mm pitch Molex socket (https://octopart.com/200528-0270-molex-103216449 looks fitting altough 1mm too wide (I think the footprint from Logitech aren't accurate for the outer dimensions)).
I found ARROW as seemingly the only supplier for this socket wich has 32MOQ but thats a bullet I am able to swallow.
Whats bugging me is that I am unable to find a distributor for the corresponding ribbon cable. Is this an outdated model or why is it impossible to find it?
The cable I am looking for is Molex Premo-Flex.
Or could buying a 30pin and slicing 3 lines off work?
« Last Edit: October 27, 2021, 07:53:06 pm by roffelkartoffel »
