Author Topic: Remove the load of buck converter  (Read 1247 times)
Offline luis.ramirezTopic starter
  • Country: ve
« on: May 18, 2016, 12:50:50 am »
I have a buck converter that is delivering 6A to a load of 3ohm load.
I'm measuring the output current and stop increasing the dutty cicle when the current reach 6A, at this moment the output voltage will be 18V. A few second after reaching this point the resistance will break and I will have and open circuit at the ouput.
My concern is the following, the inductor's current can't change inmediatly, I guess I'll go to the capacitor increasing the output voltage, It is a risk to damage the power supply or the driver circuit because of a backward current?
Offline Ammar
Re: Remove the load of buck converter
« Reply #1 on: May 19, 2016, 12:43:33 am »
This very much depends on the design of the converter. That is, whether it is designed to work in continuous mode or discontinuous mode. Generally, SMPS need to be loaded to work properly. Whether any damage occurs to it though depends on the design.
Online Fungus
« Reply #2 on: May 19, 2016, 07:53:02 am »
As noted, it depends entirely on the design of the converter.
If you're worried then you could add a clamping diode across the inductor just to be safe
« Last Edit: May 19, 2016, 08:39:28 am by Fungus »
