Author Topic: Make a dupont /pin header connector very high  (Read 505 times)
Offline SaimounTopic starter
« on: May 15, 2024, 07:27:19 am »
Hi :)
I've got a main PCB with a pin header and I want to connect a second PCB to it, but because of the design, that PCB is quite "far away" (about 15 / 20 mm).
Ideally I would like to avoid using a cable, but rather have a simple pin header on the daughter board which will connect with the pin head on the main board.
Any ideas on how to raise or find a very high connector?
Thank you!
EDIT: ok sorry I spoke too fast, after a quick search it seems that the way to go is a simple through-hole female header (the header on the main board is 1.27mm) with long pins like that.
But then what about the assembly (for production), can the header be mounted at a specific height? It would probably need a custom plastic part underneath to mount it at the correct height, no?
« Last Edit: May 16, 2024, 07:43:43 am by Saimoun »
Offline xvr
  • Country: ie
    • LinkedIn
Re: Make a dupont /pin header connector very high
« Reply #1 on: May 15, 2024, 10:57:49 am »
The following users thanked this post: Saimoun
Offline coromonadalix
« Reply #2 on: May 15, 2024, 01:39:01 pm »
2.54mm  0.1"  pitch
https://www.pololu.com/product/2748
you can search there for other models /  male   etc ....
when you say 1.27"  is it the pitch  or the physical size ?
« Reply #3 on: May 16, 2024, 07:44:54 am »
Thank you both :)
And I meant 1.27mm ha ha not inch sorry - so 0.05'' pitch
