Cost doesn't matter, and no, i'm not making it myself!
I'm trying to establish if there is a hope-in-hell of fitting an isolation transformer into an existing bit of kit (a 150kW DC supply). It's currently connected to a 330kVA iso xformer, which is, as you would expect massive!
It certainly doesn't need to be continuously rated, say 70% continuous and a max of 3min at peak power. It is going in a 'smart' system, so we can monitor temps / currents or what ever for safeguarding etc
The package space i have is under 50% of the size of the current 330kVA unit, so i need to push the limits somewhat, both in terms of winding I2R losses (oil to water cooling) but also probably in terms of core saturation (take a reduction in efficiency, as i have effectively an infinite supply to drive it from)
For me, what max_torque wants to do is clear.
He wants to remove the current transformer of 330Kva that is outside the 150KW power supply (probably to save space) and replace it with a transformer placed inside the cabinet of the 150KW power supply.
The volume available in this cabinet is 50% that of the current transformer of 330KVA's.
Therefore, any solution proposal with equipment placed outside of the cabinet is of no interest.
In summary, to solve this problem, we need to:
1) Measure the
RMS line current of the 330KVA transformer with the fully loaded power supply to determine the maximum power in KVA's actually consumed.
2) determine the maximum conditions of use. (Load x duration)
3) check whether forced ventilation is possible or not (depends on the 150KW power supply cabinet, we have no details about it ... what brand, what model?) If possible, what's the cold air max temperature ?
4) it is necessary to have a drawing of the available volume with the max. dimensions.
5) What are the network voltage specifications?
6 ) What is the load of the transformer? Bridge rectifier? What kind of filtering? Head Capacitor or head Inductor?
7) what are the acceptable variations of the secondary voltage at idle / full load?
8 ) What are the characteristics of the current 330 KVA's transformer? (Copy or picture of transformer nameplate.)
9) Pictures of the 150KW power supply, with door of the cabinet open.
