Author Topic: High temperature, low viscosity epoxy  (Read 2195 times)
Offline blueskullTopic starter
  • Country: cn
  • BA7LKP
« on: January 14, 2018, 11:16:17 am »
If I am going to make a BGA mock up (a small module in a BGA package), what kind of encapsulant should I use?
It seems like IC related materials are only traded within the IC business, and they rarely end up in the wild.
Is there any way I can get some molding compounds (quartz filled plastic beads) or 2-part epoxy that will survive SAC305 reflow temperature?
I'm looking for a small package, less than 0.5 kG. Any suggestions where can I get my hands on such materials?
« Last Edit: January 14, 2018, 11:25:17 am by blueskull »
Offline t1d
Re: High temperature, low viscosity epoxy
« Reply #1 on: January 14, 2018, 11:22:33 am »
Research electronic "potting" materials. Some of that should be high temp. Should be available from Mouser, Digikey, etc.
Offline jpanhalt
« Reply #2 on: January 14, 2018, 11:49:53 am »
EpoTek will be closed this coming Monday (1/15/18).
Offline sdouble
« Reply #3 on: January 14, 2018, 12:39:49 pm »
i have a good experience with epotek.
serious company.
Offline HighVoltage
« Reply #4 on: January 14, 2018, 01:39:43 pm »
In the USA I have used the Ellsworth high temperature epoxy successfully.
A great company to work with
Henkel Loctite STYCAST 2662 High Temp Epoxy Encapsulant Black 1 qt Can
https://www.ellsworth.com/products/by-manufacturer/henkel-loctite/encapsulants/epoxy/henkel-loctite-stycast-2662-high-temp-epoxy-encapsulant-black-1-qt-can/
Offline lewis
  • Nullius in verba
« Reply #5 on: January 14, 2018, 05:34:22 pm »
Silicone resin any good for your application? http://uk.farnell.com/electrolube/sc3001rp250g/resin-silicone-optically-clear/dp/2075077
Low viscosity, withstands 250*C for 30min, optically clear.
I will not be pushed, filed, stamped, indexed, briefed, debriefed or numbered.
