Small-ish thermos bottle filled with water, boiling keeps the temp at 100C
Thats basically a pressure cooker. It wont work, the pressure will just keep rising and water boils at higher temps at higher pressures. I guess you could put a valve so you keep pressure constant but you'll run out of water eventually.
Anyway, maybe you could use thermoelectric cooling down there?
