McMaster Carr sells beautiful stainless steel jacketed probes with MgO or other ceramic insulation.
That Said, Our commercial TC welder at work consists of 24,000 uF of low ESR capacitor, an internal 1-24v adjustable cap charger, and a metal can power scr. Triggering is provided by a string of closely spaced gate pulses to .
reduce dud welds. Wiring to the electrodes is perhaps #8 in a very flexible welding grade flex cable.
One discharge wire (Like Litz inside) is welded to a pair of pliers, the other to some sort of moderately porous graphite composition block that is almost ceramic like in composition.
When I opened it up, my first thought was why didn't I just build this.
However whatever is mixed with the graphite and sintered is worth having. Especially if your making 100 identical TCS a year like I need to do in one batch.
You can get a good weld with a big copper stud as "side B" instead of the composition. You just have to clean it fairly often.
I usually tightly wrap a few turns of 18 ga chromel tightly around the copper or alumel, snip the inner wire flush to the outermost coil turn, grab both conductors with the pliers. Take the exposed final turn with inner, press it firmly onto the block and hit the fire button. I'll then hit it with a second pulse. On good welds you do not hear the audible snap on the second , but you will see the EMF shake the welding cable.
If set correctly I end up melting and fusing 1/2 turn to the inner.
Beading my old way.
Hf start TIG welder set for short pulse after the Argon comes on will nicely bead type T and Type K. Have not tried it with other pairings. Clamp the twisted pair into a vise.. Make the bench vise one side of the tig circuit. If needed line the vise jaws with copper plates.. Hold the Tig head about 1/16 inch above the new junction. Hit the foot pedal. Flash Bang Click puff of oxide
done. Hf in this case means the welder has the little Tesla coil built in to start the arc without contact.
You will never see me use the cheap plated connectors.
Steve
