Hi, I am converting a board I did to a lower profile design. That meant changing a 47µF electrolythic with a ceramic one. Is the board flex going to affect the capacitance too much, at this high values. Mind you, it's a 1.6mm thick prototyping board with some connector on it. (OK, I admit it. It's an Arduino compatible).
Thanks again!
