Author Topic: Speed of eye response to red vs green LEDs  (Read 5522 times)
Offline james_s
Re: Speed of eye response to red vs green LEDs
« Reply #25 on: August 16, 2018, 07:01:00 am »
At turning on? Why? And by how much?
Surely not enough to be visible. It may take some finite amount of time for the phosphor to respond and start emitting light but that's going to be a very *very* small amount of time in human terms.
Offline hamster_nz
« Reply #26 on: August 16, 2018, 07:18:43 am »
You would think nobody here had a few spare LEDs, a micro controller, an couple of LDRs or photodiodes and a dual-channel scope....  ;D
I might do some tests tonight and post results.
Offline iMo
  • Country: sm
« Reply #27 on: August 16, 2018, 06:37:02 pm »
https://en.wikipedia.org/wiki/Rhodopsin
https://en.wikipedia.org/wiki/Visual_phototransduction
The LEDs are pretty strong source of light today. It could be the above processes apply in a much stronger way when starring into the red/green/blue LEDs thus there are delays in the processing the colors.
« Last Edit: August 16, 2018, 06:54:17 pm by imo »
Offline onesixright
« Reply #28 on: August 16, 2018, 07:16:18 pm »
Apart from being an attention test, that is also a good proof that we don't perceive what the reality is, but what the mind expect it to be. We are not aware about this, but what we perceive is a continuous fabricated daydream guided by reality, instead of perceiving the reality.
Yeah, and thats says what about eye-witnesses ?
Offline GreyWoolfe
  • NW0LF
« Reply #29 on: August 16, 2018, 08:33:43 pm »
What are you doing even leaving eyewitnesses? :box: >:D
Offline StillTrying
  • Country: Broken Britain
Offline hamster_nz
« Reply #31 on: August 16, 2018, 10:30:52 pm »
Added a few 5mm LEDs.
www.eevblog.com/forum/chat/20w-halogen-bulb-viewed-by-a-photodiode/msg1751210/#msg1751210
Excellent results! At least for your LEDs we are talking a fraction of a ms. I did some inconclusive testing with a LDR last night.... the LDR was too slow to be of any use.
Offline IconicPCB
« Reply #32 on: August 16, 2018, 11:43:33 pm »
The eye gets fooled by frame rates greater than 18Hz.
That would be a good starting point
