Author Topic: Source a transformer with multiple secondaries  (Read 1182 times)
Offline MarkFTopic starter
« on: January 07, 2019, 06:17:10 pm »
I would like to build a simple linear power supply with three outputs (i.e. 5VDC, +12VDC and -12VDC).
I want to keep the 5V GND independent of the +/-12V GND.  Only looking for a 1A capability max on each output.
Does anyone know where I can find a single transformer with three secondaries instead of two transformers?
« Last Edit: January 09, 2019, 01:43:21 pm by MarkF »
Offline schmitt trigger
  • Country: mx
Re: Source a transformer with multiple secondaries
« Reply #1 on: January 07, 2019, 06:25:40 pm »
Perhaps the easiest would be to purchase a toroid transformer which can provide the +/- 12v supplies, and then hand wind your own winding for the 5v supply. Window area allowing it, of course.
Offline station240
« Reply #2 on: January 07, 2019, 06:57:22 pm »
You can get multitap transformers, been out for decades.
I have no idea where you get them in the US, all the electronics stores in Australia sell them.
Try searching ebay for "transformer 9V+9V 15V+15V", seems to be some usable results there.
The following users thanked this post: MarkF
Offline Benta
« Reply #3 on: January 07, 2019, 07:22:12 pm »
Or just get it made to order. No big deal nowadays. There are transformer companies that'll make one-offs. Search the interwebs.
« Last Edit: January 08, 2019, 03:52:17 pm by Benta »
Offline Zero999
  • 0999
« Reply #4 on: January 08, 2019, 09:34:45 am »
Digikey sell them but the power rating for the 12V secondary is a bit less than your requirements, at only 250mA.
https://www.digikey.co.uk/product-detail/en/signal-transformer/14A-30-512/595-1705-ND/1117954
How about using two transformers or a switched mode power supply for the 5V part, which presumably isn't so sensitive to noise and ripple?
Another option is to use a transformer with two secondary windings with one connected to a voltage doubler to get the +/-12V, although it would need to be considerably over-rated.
