Author Topic: High voltage analogue multiplexer/demultiplexer circuit  (Read 897 times)
Offline edbaTopic starter
« on: April 17, 2020, 07:00:02 pm »
Hi
Does anyone know how to build a high voltage 8 channel analogue multiplexer/demultiplexer circuit that would be able to switch a high voltage (1500-2000V) to anyone of the eight inputs/outputs whilst the other inputs/outputs were at 0V? It would be like a high voltage version of the 4051.
The only way I can think of doing this is by using eight individual high voltage reed relays, but this would be expensive espeicially if I wanted to increase the multiplexer/demultiplexer inputs/outputs?
Edba
Offline Zero999
  • 0999
Re: High voltage analogue multiplexer/demultiplexer circuit
« Reply #1 on: April 17, 2020, 07:38:20 pm »
I suppose it's theoretically possible with photocoupled MOSFET solid state relays, but they will have a much higher leakage current and won't be any cheaper than good old relays.
Offline Neilm
« Reply #2 on: April 18, 2020, 04:12:19 pm »
I would find some decent relays. You are up at voltages where creepage and clearances are starting to become significant so anything you buy will be esigned to meet them and will start to be expensive for it. SSRs that are good for that level of voltage will be more than a relay.
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Tesla referral code https://ts.la/neil53539
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #3 on: April 18, 2020, 06:36:56 pm »
What leakage current?  What bandwidth, or what maximum isolation capacitance?  What transient voltage or current rating?
Seven Transistor Labs, LLC
The following users thanked this post: Yansi
Offline David Hess
  • DavidH
« Reply #4 on: April 18, 2020, 11:36:52 pm »
It can be done with a photovoltaic isolator driving a pair of back-to-back high voltage MOSFETs per switch.  I have seen one circuit which used 4 of them to make a high common mode voltage flying capacitor to replace a high voltage instrumentation amplifier.
« Reply #5 on: April 20, 2020, 04:06:23 pm »
Hi
The bandwidth is DC and leakage current around 150nA,
Br
Edba
Offline Zero999
  • 0999
« Reply #6 on: April 21, 2020, 10:21:52 am »
Then forget about using anything solid state. Relays are the only viable solution. You'll need to pay a lot of attention to creepage distances to get that kind of low leakage current, which would require an insulation resistance of >10G.
