My question, is there a simpler way to do this or a better way?
Quote from: Radardude on January 17, 2014, 02:03:05 pmMy question, is there a simpler way to do this or a better way?If you are going to fool yourself that putting an RC on a digital signal is a good solution, at least put a schmitt trigger input part after it.
I think an mcu is the best idea as you can easily experiment whith different times. You could use a 555 time but it is more difficult to experiment whith diferent times mcu is just the easiest. All you need is a cheep small mcu like picaxe 08 if you don't have another one in your BOM or you could use any mcu you want.
How about just a standard time delay relay. Nice, cheap, ready to go, and reliable. Amazon has many upon manys of them.
