Author Topic: Super-small FPV quadrotor  (Read 2675 times)
Offline RCMRTopic starter
« on: September 08, 2012, 09:30:52 pm »
Most people have seen quadrotors these days.  Four electric motors attached to four props, some gyro-stabilization and an RC set mean you can hover about  and have a ball.  Dave is even contemplating one for getting some cool canyon videos.
You can spend a bit of money and an awful lot of time farting around building your own quad and break a lot of props during the learning process -- but these days you can also spend about $100 and buy a tiny (100mm between motor centres, 32g) "off the shelf" machine like the Walkera Ladybird QR.
I bought two of these little quads a few months ago and have been having a ball.  Although they're *tiny* and use a single 260mAH lithium cell for power, these birds can actually carry an HD keychain camera (weighing 17g) to get some impressive aerial video.
However, I wanted to do live video and fly FPV (first-person view) so I fitted a sub-2g video camera and a 200mW 5.8GHz video transmitter module.  A bit of bodging was needed to add a regulator for the video transmitter module but it all seems to work pretty well.
Here's the build-video.  Some "pilot's eye"  flight footage (recorded live video) to follow when the damned winds and rain stop around here.
Offline Rerouter
Re: Super-small FPV quadrotor
« Reply #1 on: September 08, 2012, 10:43:48 pm »
interesting, however i feel crosswinds would be a moderate problem for such a small quad, still interestered to know how long of a flight time you get out of it ?
« Reply #2 on: September 08, 2012, 11:44:09 pm »
Without the FPV gear onboard, these little quads are good for about 6-7 minutes.
The extra drain of the FPV gear (about 250mA) will reduce the flight time (probably by a minute), as will the small amount of extra weight.
I'd expect to get around 5 minutes flying.
And they handle the wind remarkably well.  I've flown them in the turbulence of my back yard with a 15kph wind and experienced no problems at all.
« Reply #3 on: September 12, 2012, 08:37:44 pm »
First flight tests:
