Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
High Voltage Generator Mosfet drive flyback transformer
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: High Voltage Generator Mosfet drive flyback transformer (Read 300 times)
mu34tant
Newbie
Country:
on:
June 29, 2022, 11:14:48 pm »
I want to use this driver board (
https://www.ebay.com/itm/384300834133
) with this transformer (
https://www.ebay.com/itm/402679163644
). The driver board is designed for 12v. The transformer is primary is setup for 125v. The driver board uses UC3845b timing chip and can be powered offline. I will have a 125v source (
https://www.ti.com/lit/ds/slvs036n/slvs036n.pdf
) figure 13. I am going to use this mosfet that has characteristics of the 110n8f6 except a much higher Vds (
https://www.mouser.com/datasheet/2/196/Infineon-IPP051N15N5-DS-v02_01-EN-994624.pdf
) 051n15n5. There will be a common ground for the 12v and 125v supply. There is a 1ohm 5w resistor between 12v supply and mosfet source. I was thinking of going with a 0.1ohm 5w resistor between 125v source and 051n15n5 source. Is this a good idea?
Last Edit: June 29, 2022, 11:16:43 pm by mu34tant
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
Advertise on the EEVblog Forum
