Author Topic: Jupiter-T GPSDO Communication  (Read 5166 times)
Offline davorinTopic starter
« on: July 11, 2014, 10:14:13 am »
Have now all components together to build a GPSDO 10MHz reference oscillator..
When I power up the GPS module I receive the standard 0xFF, 0x81 start sequence in the reply...
Though when I try to communicate with it there seems to be no reply at all....
For example the command "@@Cj" should return model, version and serial number...but doesn nothing...
Re: Jupiter-T GPSDO Communication
« Reply #1 on: July 11, 2014, 11:22:43 am »
Found some documentation and examples here....but still no luck with it....for example just how to find out if the GPS has a lock...
http://www.casde.iitb.ac.in/IMSL/motion/gps/
Connecting my HP5335A display for the first 5 - 10 minutes a value of 10000.360 Hz...then goes down to 10000.177 Hz...which is reproducible when power-cycling the Jupiter-T GPS module...
« Last Edit: July 11, 2014, 11:46:03 am by davorin »
« Reply #2 on: July 11, 2014, 12:36:55 pm »
As per example in the Word document in the link above....getting the pinning status should be possible with:
echo -ne '\xFF\x81\xF4\x03\x00\x00\x00\x48\x0D\x32' > /dev/ttyUSB0
Still no output....only during power-up...
Offline jpb
« Reply #3 on: July 11, 2014, 12:54:43 pm »
It sounds as if the Jupiter is not receiving your signals - perhaps there is a fault on pin J1-9. You may even have a faulty cable - have you double checked it with a DMM for continuity?
« Reply #4 on: July 11, 2014, 01:07:31 pm »
I see the signal going to pin 9...
Also..happens with both of my TU60-D001 modules...
Bitrate is also correct when sending...just checked with a simple '\xAA' > /dev/ttyUSB0 and my DSO...
« Reply #5 on: July 11, 2014, 01:17:12 pm »
Hmm...should work with a regular USB2TTL serial adapter, right?
Not that the Jupiter expects RXD to be inverted.....
Offline Andy Watson
« Reply #6 on: July 11, 2014, 01:36:33 pm »
Are you sure about that? The jupiter GPS that I've used required its serial output converting to RS232 level (including inversion). Also, check the mode that it boots-up in. I think it defaults to the NMEA message mode.
« Reply #7 on: July 11, 2014, 01:43:13 pm »
They default to binary mode...as it sends after reset this message with the regular 0xFF81 flag:
\0xff\0x81\0x9c\0x04\0x01\0x00\0x00\0x00dy\0x00\0x00\0x00\0x00
« Reply #8 on: July 11, 2014, 03:28:04 pm »
Just stumbled upon this thread:
http://en.it-usenet.org/thread/16759/1388/
And tried myself with the Motorola WinOncore 12 software, and it is indeed sending information back when asked for the receiver id:
Also it sends data continuously when opening the command monitor...
« Last Edit: July 11, 2014, 03:33:03 pm by davorin »
« Reply #9 on: July 11, 2014, 04:16:06 pm »
Some step forward (o;
Sending this:
echo -ne '@@Cj)\x0D\x0A' > /dev/ttyUSB0
returns the module information:
@@Cj
COPYRIGHT 1995-2004 NAVMAN LTD.
SFTW P/N # 0000
SOFTWARE VER # 93
SOFTWARE REV # 07
SOFTWARE DATE  01/16/2004
MODEL #    R01
HDWR P/N # TU60-D125
SERIAL #   407132508
MANUFACTUR DATE 401//12070
OPTIONS LIST    5843
Sending:
echo -ne '@@Ea\x01\x25\x0D\x0A' > /dev/ttyUSB0
initiates the sending of the status/position information every 1 second...
« Reply #10 on: July 11, 2014, 05:08:03 pm »
Seems to be plain Motorola binary format it accepts after power-on:
https://www.febo.com/pages/hardware/VPCommands.pdf
