It really depends on the pollution class for which you are designing. For a new, clean pcb, at sea level, in a low humidity and clean environment 1mm is a large distance. It would take >5Kv to jump across that gap.
But an old, "dirty" pcb (flux residue etc) at altitude, with high humidity and in a dusty environment is a VERY different proposition indeed!
And with all things MOSFET, the maximum ratings are really just a guide, typically you'd only use between half and two thirds of the ultimate capability for your "DC" values, leaving room for dynamics overshoots etc. So, you wouldn't actually use a 900V mosfet on a 900V dc link....
