Author Topic: High Voltage Pulse Generator Circuit  (Read 4029 times)
Offline DejanCTopic starter
« on: December 31, 2023, 04:05:30 am »
I am looking for ideas to create a HV pulse generator circuit. I do not need all the components to be from scratch. The easiest way I have seen online would be by using a coil and switching it open/closed quickly to generate the high voltage but a quickly collapsing magnetic field. That is, using a MOSFET in combination with a PWM signal generator, a gate driver and a coil of course. Does anyone have any experience with this and and suggested ICs/schematics?
I am looking for about 1-2 kV (possibly higher) and no larger than about 10 MHz pulse frequency.
Offline Andy Chee
Re: High Voltage Pulse Generator Circuit
« Reply #1 on: December 31, 2023, 04:12:16 am »
I like this one (although it plays music, you can use it for plain boring pulses as well):
https://franzolielectronics.com/easy-flyback-i/
« Reply #2 on: December 31, 2023, 05:08:21 am »
This is a good start but I am hoping for as simple as possible (without the zero crossing detector)?
Offline Andy Chee
« Reply #4 on: December 31, 2023, 05:31:30 am »
This is great, but I would love a little more flexibility with the PWM (setting frequency and duty cycle for example)
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #5 on: December 31, 2023, 05:38:15 am »
What load impedance? What rise/fall time or other waveform? Is this for EFT testing, something more specific, or something entirely generic (high voltage for funsies)?
Seven Transistor Labs, LLC
« Reply #6 on: December 31, 2023, 05:48:47 am »
Load impedance is unknown. Ideally would be in the ns range of rise/fall time, wishing to producing a unipolar pulse, upto 1 MHz (or lower). Could be categorized under high voltage for funsies, but it is for prototype development and experimentation.
« Reply #7 on: December 31, 2023, 05:56:29 am »
Basically would like to create controllable pulses based on a inductor/MOSFET switch combination like in the video below:
I am looking for any DIY projects that anyone has seen with specific advice on ICs/FETs/PWM modules to use, etc.
Offline T3sl4co1l
« Reply #8 on: December 31, 2023, 12:30:31 pm »
Prototyping of what?  Like, there are actual applications for signals like this (undefined* impedance, high voltage, ~ns edge or width, rep rates up to MHz), but it's esoterica like particle accelerator beam dump (deflector plate) drive, or Pockels cell drivers (switched/pulsed lasers).
If you just want to look at something on a scope... then do that [the video] I guess?  Isn't anything fancy, anything will do.  Break it down to simpler problems: what is a gate driver, what does it need to do?  What does a MOSFET need for input? Output? How to design switching circuits?  What does the inductor need to do?  How can you model the RLC equivalent turn-off (flyback) circuit, and resulting transient waveform?  Why does it ring?  What is the peak voltage determined by?  (And why does it blow transistors?)
Offline Terry Bites
« Reply #9 on: December 31, 2023, 03:53:50 pm »
Marx generator?
Lighning fast pulses!
Offline jonpaul
    • IEEE Spectrum
« Reply #10 on: December 31, 2023, 04:30:26 pm »
Lightning on Demand
https://www.lod.org/
Old friend Greg LEYH
j
The Internet Dinosaur..
passionate about analog electronics since 1950s
Offline zrq
« Reply #11 on: December 31, 2023, 11:24:29 pm »
Maybe this company have something suitable for you? kV and tens of MHz sounds difficult though.
https://www.behlke.com/
« Reply #12 on: January 02, 2024, 03:39:26 pm »
I am looking to power a device with pulsed power/voltages and read the output RMS current and RMS voltage on a scope. I am thinking of a PWM module + gate driver (maybe) + FET + inductor (high side switching) to create this high voltage spike.
Am I correct to say that for a resistive load we can use RMS voltage/current on the scope to readout average output power?
Offline Marco
« Reply #13 on: January 03, 2024, 08:52:15 am »
High voltage half bridge with GDTs, either with GAN or SIC mosfets. Nice flat top pulse and not load dependent.
http://ticnn.tju.edu.cn/064709_1_5.0142031.pdf
Offline daqq
  • Country: sk
    • My site
« Reply #14 on: January 04, 2024, 08:14:42 am »
Offline inse
« Reply #15 on: January 04, 2024, 08:50:33 am »
Just a side note: 2kV 10MHz kV/ns those orders of magnitude are not for the faint hearted nor the beginners.
Do you have the necessary equipment to debug/fine tune your setup?
High voltage high speed probes, e.g.
Also consider that high voltage probes have a frequency derating
« Last Edit: January 04, 2024, 08:54:34 am by inse »
