Electronics => Projects, Designs, and Technical Stuff => Topic started by: ROBOT on March 05, 2016, 11:21:12 pm
Title: Higher Melting Point Solder?
Post by: ROBOT on March 05, 2016, 11:21:12 pm
Anyone know where I can find some high melting point solder? I need it to be higher temp then the typical lead free.
Title: Re: Higher Melting Point Solder?
Post by: Alex Eisenhut on March 05, 2016, 11:28:38 pm
ebay
Post by: johansen on March 05, 2016, 11:35:09 pm
Lead free plumbing solder melts at 450-460F
95% Tin and 5% Antimony.
Post by: ROBOT on March 06, 2016, 12:00:41 am
That's extremely low.. I'm looking for something above 270C
Post by: bmwnomad on March 06, 2016, 12:18:17 am
How about some Sn05Pb95 (5% Tin, 95% Lead)?  301-314C melt range.
http://www.kester.com/kester-content/uploads/2013/06/Alloy-Temperature-Chart-15Feb11.pdf (http://www.kester.com/kester-content/uploads/2013/06/Alloy-Temperature-Chart-15Feb11.pdf)
Post by: calexanian on March 06, 2016, 02:43:56 am
Eventually you will get up into brazing alloy range. Typically you need a torch for them but I have seen some that flow at dull red heat. They are very common in auto body repair.
Post by: pelud on March 06, 2016, 03:46:47 am
Here is some multicore HMP series (SN5/PB93.5/AG1.5), and melts around 296-301C:
http://www.digikey.com/product-detail/en/multicore/397952/82-140-ND/2498938 (http://www.digikey.com/product-detail/en/multicore/397952/82-140-ND/2498938)
Post by: Whales on March 06, 2016, 05:54:07 am
Straight lead.
http://www.garelicksteel.com/pdfs/Melting_Points_of_Common_Metals.pdf (http://www.garelicksteel.com/pdfs/Melting_Points_of_Common_Metals.pdf)
Be wary with any solution: what you are soldering to will alloy with your solder.  This may have a lower melting point.  If possible, go for crimps.
Post by: PointyOintment on March 06, 2016, 07:00:56 am
Here you go—pick one: https://en.wikipedia.org/wiki/Solder#Solder_alloys
Post by: blufeb95 on June 27, 2016, 03:22:05 am
 don't know if you are still looking for higher melting point solder but you can score 1lb rolls of Kester 44(RA) or 285(RMA) Sn10Pb88Ag02 for quite cheaply, the Melting Range  is 514-570°F / 268-299°C
Post by: HighVoltage on June 27, 2016, 09:53:50 am
What is your target melting point?
Felder in Germany will mix solder for custom specifications
https://www.felder.de/ (https://www.felder.de/)
